Back spacing on front wheels
HemiD@rt
AZ
18x8 wheels up front, should I go 4.5 bs or 5? Going to run 235/40/18 tires.
Thanks!
Sorry if this has been answered before... All these offset and back spacing numbers has my head spinning big time! :banghead:
My 17x8's have zero offset which is 4 inches of back space. The tire size is 255x45x17.
I'm running a 18X9 and have 6"+/- back space. With the 73+ disk brakes and the 11-3/4" rotors.
If it was me I would get the 5" backspace can't go wrong there with an 18" rim IMO. The 4.5"B.S. is going to be getting close to the fender lip maybe even sticking out a bit.
I run a 17x8 with 4.5BS, 225/40-17 front. When I had the 17x8 with 4.75BS I had a 245/40-17 front tire. I'd go with a 4.75 or 5" BS for an 8" wide wheel.
run 5" backspacing. That is a tall tire setup that will rub the fender lip if it sticks out (less backspacing) too much.
What size front tires do you have on that?
I Agree going with the 4.5" backspacing is to close to the fender go with the 5" backspacing on an 8" wide rim
Thanks guys. I went with the Boss 338 wheels with the 5" of backspace.
