Darthomas
Ashamed to be seen in foreign cars
Ok, it's on my friend's 63 three on the tree, but I see the switch mounts the same as a four speed, and saw an old thread on this, with no definite conclusion reached.
Reverse engages just fine, but to make the lights work he has to pull up on the handle.
The internal lever doesn't seem to touch the ball on the end of the switch.
I haven't gotten under there yet, except to feel/confirm the wires are on tight.
Is there normally a washer or seal at this switch that might simply be too thick?
Will I likely be able to tighten it more to get it to work correctly?
If there's a sealing washer, could I delete that and then seal it with silicone?
