[WANTED] Backing plates, A Body 8 3/4 10x1-3/4"
Dana67Dart
The parts you don't add don't cause you no trouble
Northern Colorado
I'm looking for 1 to 3 backing plates
I need at minimum 1 passanger side
(Opposite e brake hole from one in the photo)
I would also take another set.
Prefer little to no rust putting.
1967 or 68
10 x 1-3/4
8-3/4
1967 and 68 (note: no piston stop tabs)
69 and up (I don't want these) note the tabs.
I have a set from a 68 fury complete set
There’s no real difference between a body and any other body when it comes to backing plates on the 8 3/4 it’s going to depend on the year
I know that it’s the only difference between them
Then you would know that those are the only ones he can use, due to the unique A body only axle offset. And he can only use the 1 3/4” brake shoes, also an A body only width, Fury would be at least 2”, probably more like 2 1/2”
There is definitely a well known difference between backing plates A body vs B, C, E body 8 3/4 housings.
It looks like they used A body 8 3/4 backing plates on bigger bodies but with 7 1/4
While searching for part numbers, I did see this...
