Bad amp gauge
My65
New Member
San Jacinto, Ca
Hey everyone. I new to the group. I'm in the process of restoring a 65 Barracuda. It was a running project but now I have a no fire issue. Due to the amp gauge going bad. Until I'm able to replace the whole cluster. How do I bypass the amp gauge to be able to start my Barracuda so it can be drivable en again?
Take the two wires on the back of the amp gauge and bolt them together tightly. Yes, one is red and one is black, but they are both power. You will want to tape over them very well so they will not touch a ground anywhere. You may also want to read over this article.
The amp gauges were never intended to last this long. You can get a modern under dash amp gauge and if you are careful, you can hook it directly to the existing Amp gauge wires and mount it under the dash. There are a host of positive diagnostic advantages to an amp gauge and a voltmeter and they don't do the same thing.
If you can't find the ammeter here then you can check these vendors for part number 2496503.
hiltopautoparts.com
ams obsolete
Expensive but they are available.
Depending the year/model/dash the ammeter is fairly common to just as rare as any other one year only part. For example the bulkhead multi-connector on your '65 is different than 64 or 66.
They don't age out and there is only one moving part - the needle, so they don't wear out mechanically as far as I've ever seen.
Ammeters, or more commonly the connectors, can get damaged by water (leaks in dash, windshield or cowl).
They can also be damaged electrically when overloaded. If the needle swings 1/2 way toward either charge or discharge, that's 20 amps going into or out of the battery. That's about the max the circuit should ever be subject to, AND 20 amps for long periods of time will heat up and damage connectors. If you have a damaged battery or alternator feed connection on the bulkhead, this is probably the reason. Twenty amps or more continuous to the battery for recharging means the alternator is sending that plus whatever is needed to run the engine, brake lights, turn signal etc.
The rest of the instrument panel is isolated from the ammeter. So depending on the cause of the ammeter damage it is likely the rest of the instrumentation and lighting is OK. This post has photos and a diagram.
If you have to bypass the ammeter, then it is advisable to have some way to judge the electrical system. Underdash ammeters used to be common in aftermarket gage sets (as many of Mopar's competitors didn't provide gages on their base models). Easier generally is some sort of voltmeter. Even your hand held multimeter. Run the engine and make sure the alternator is producing power around 14 V and it doesn't follow the engine rpm.
Without an ammeter, we can assume the battery is getting recharged if the alternator is producing power at 14 Volts.
However don't know the charge rate. That requires an ammeter.
Heh. Suppose should have asked before typing all that.
What is the problem you are observing with the gage? and why do you think that is the cause of the no start?
During start the gage should show very slight discharge. About the same as when stepping on the brakes, less than when turning on the headlights.
If the gage needle moves as expected when stepping on brakes or turning on a light, then the circuit through the gage is probably OK.
If the gage and any connections show the type of damage pictured in the link below, that's another story.
