I have had an email exhange with the owner. Seems like an up front guy and doesn't appear to be hiding anything. I will still try to drop by to assess the true state...You will notice that he has updated the kijiji posting with more pictures and info.... here's part of the exchange
Owner: Before I do that, I want to make sure that you understand that both need alot of work, and are not driveable by any means. That being said, Im also only looking for cash deals, no trades. Where are you coming from?
Me: Thanks - I'm coming from Kitchener.... I appreciate the warning - I am assuming the back half of the Challenger is a writeoff? Is the engine and tranny in "running " condition?
Owner: You assume correct, however I do have some factory frame rails for the rear. Those could go with the car if you were serious about it. The trunk floor needs replaced as well, and probably at least lower quarters. The engine was running last fall, but the fuel pump failed this spring. So with the exception of that yes it does run and move under its own power. It would be fun to see just how much power is there, but it would be unsafe to try on any roadway. The cuda is much more solid, but has had patchwork done to it. The plan was to transplant driveline and vitals to the Cuda after it was fixed and painted. But I came across another vehicle to do. Did you want to set up a time to look at them?
