Barracuda and Dart inner fenders
That's right Bill. Under the exterior sheetmetal the basic frame structure are identical for each body type. A Road Runner inner fender will work with a Charger. A Dart inner fender is the same as a Barracuda. A bodys fit A bodys. The same with B, C, and probably F...M...etc.
Thanks John, I thought they were the same.
Mine are shot to s**t. I'll have to go junkyard
shopping when the weather breaks.
I was always lead to believe that the Barracuda had a larger wheel well than the Darts. The SS car Darts required the wheel wells to be cut out to fit big tires while the Barracuda didn't.
The sheetmetal on a Dart's rear quarter panel wheelwell had to be opened up, but the original reference was the front inner fender wells under the hood. The only exception might be pre-`67 A body's. I think they're unto themselves.
Yup. I've cut patches from 75 model inner fenders to use in 67 car. Only difference is a screw hole here and there.
