[WANTED] Barracuda Belt Molding Clips
tubbedamx
Location Boise, Idaho
Boise, Idaho
Looking for 4 more belt molding clips for a 67 Barracuda . Bag I bought has fourteen instead of 18.
Can pay with PayPal, shipping to 83709
thanks
Let me look. They should have a seal on them as well. I do not think I have any of them that are good but sourced very reasonably from a company up north. Have you checked with RPM?
These maybe for the rear wheelhouse trim as dimension is key. But both use a sealing strip.
Splash shield is different, but the second link is spot on!
thanks for the confirmation ordering some for my self ...getting alot of the smalls for paint next year !!!
I did not know James Filmore at DMT was offering these now! I got mine from like JD clips or something. Still have not looked for his website info to post. If you search my posts I had put it out there before with part numbers. For both the belt and wheelhouse clips.
By the way if you order new splash shield rubber from DMT he includes the correct stainless clips with them. Don’t forget about the A-bodies discount too!
I might be wrong but I believe the ones you posted are incorrect.
I think they are the same as a Charger uses ... Which is most likely where mine came from.
You can have any I dig up for free
For the OP both the belt and Fastback wheelhouse trim clips have the seal. It serves both to seal the hole in door/quarter and also anti rattle.
Found and original still on an extra quarter belt trim I have. The seal is mostly gone and compared to what i thought maybe a wheelhouse Fastback trim clip, apparently the earlier pics where wheelhouse trim clips.
Ok. They just seemed a bit small in the pics.
When you say " quarter house trim" are you refering to the interior panel trim over the wheel housing ?
The larger left is belt trim clip. The smaller right is the trim between garnish and rear wheelhouse cover trim for Fastback.
Ah .... I did not notice the size difference.
The clips in the second link in post #4 by @jazak5 are dead on and correct. DMT is great and offers discounts to A-bodies members! If I were the OP I would get them or at least find a way to add seals to what they have. Any water kept out of the door or quarter is good sense!
Aren't the seals pretty much just some thin adhesive weatherstrip or putty ?
I live at the end of Maple Grove down by the river and work at Lyle Pearson .
Are you doing a white 68 Fastback ?
