Barracuda leaf spring support
Cudak314
New Member
Frankfort
I have a 67 barracuda that has Caltrac monoleafs in it is there something that can be added to support the front leaf spring mount not to rip out of the body? Thank you
Great photo. Mounts are only as good as the steel under it.
If already mini tubbed I would consider plating both sides if I was worried about it. Longer bolt and maybe a brake line relocation (tweak) and you should be good.
Some pictures would really clarify the situation.
