Barracuda will not start! Any Ideas?
Dervco
Calgary
Fuel is not getting to the carb. Changed the pump, still not getting there. What should I do next?
Make sure your float is not stuck in your carb (stuck and thinks it is full) I would blow threw the fuel line to the carb to make sure of this.
Your fuel pick up tube (filter) in the tank could be plugged up, or make sure there is gas getting to the pump.
How do I figure out if the tank is plugged? I put compressed air in the filler hole and this seemed to get gas to the pump. if the line is compromised could the pump be sucking air with out leaking gas? Thanks for your input so far.
