Fuel Leak Help
NSdartSW
Southern California
I have a fuel like I just can’t get rid off no matter what I try and I’m out of ideas. I have a 750 Holley(PART # 0-80508S) on my 360 with a Mr. Gasket fuel line(1515) and no matter what I do one or both of the fittings where the fuel line meets the carb leaks. I’ve tried everything I can think of and I’m out of ideas. I need some help or new ideas cause I’m out and it’s getting frustrating.
Thank you in advance
Also check really carefully on the carb before and after the fitting is on the carb. Rhee could be a hairline crack in the carb boss that expands as the fitting is tightened
