BB Abody oil pan question
cawley
383 Bcuda
milton
What makes an original oil pan out of a BB Abody so different. Can any other oil pan work w/ the fast ratio steering ?
I found the following:
[ame]http://www.forabodiesonly.com/mopar/techarticles/Car_Craft_December_2000.pdf[/ame]
....... Don't know about fast-ratio steering, though.
David
The numbers and internal baffles, Most pans will work with the 67 and 68 BB idler and pitman arm, not sure about 69. Newer steering linkage will need the "notched" OEM pan.
