bb fenderwell header?
I belive that year might be different from the 67-74 years a-body,but don't hold me to it,i know that the small block is
They will not be the same. However, if you have access to a band saw and a welder, you may be able to modify them to make them work. That's what I'm currently doing.
with the straight axle set up iam going with. it may not matter, the k frame ect will be gone..
I'm working on the headers now in a 64 dart with a rb motor.I have hedman & hookers the hookers hit the bracing under the floor and the angle of the collector points up will try the hedmans today
Did not install axle yet.But the hookers hit the floor braces hard and colector kinded pointed up.The hedmans fit the body realy nice.After I removed all the brackets for the UCA.Will finish axle install when I get back home.But I do have the axle in place with no weight on it.It looks like there will be plenty of room even on the down side of a wheel stand.Will take pics after everything is tack in place and the weight is on the front end.I don't like my cars noise bleed high.Im trying to keep it as level as can and as low as I can.:oops:
