To my knowledge thats probably an aftermarket pan of some sort. the 699 and the 187 pan are the pans that work with the Big block swap. I don't believe that pan will it.
It needs to be a center sump, which yours appears to be, but there needs to be a notch on the right side to clear the idler arm. Those pans are found on C body cars.
