bb water pump
wireweld
South Dakota
Does anyone offer a reverse rotation water pump for a 400 bb, so that I can use my small block aluminum radiator that has a right hand outlet and ldft hand inlet?
Try a marine co. most marine engine run backwards
440 source has the housings that the outlet is on the passanger side. www.440source.com Mark
Finally, a part that customers have been begging us to make for years! An aluminum water pump housing that exits on the passenger side instead of the drivers side. Now you can have your choice of which side you want your lower hose to exit. In the past, the only housings available with a passenger side lower hose were the extremely heavy and worn out factory cast iron units. The choice was either to use one of those, get a different radiator (costing hundreds of dollars) or run the lower hose all the way across the bottom of the radiator (a compromise of both looks and function.) These have the alternator bosses cast into them for both early and late applications. These work great with our new aluminum water pumps, (see our water pumps page for details.) Part No: 200-1079 - Water pump housing Aluminum - Passenger Side Lower Hose - NEW. Price: $$89.95
