(If I have mid represented something let me know)
I'm new to Big Blocks so I'm learning as I go along.
I mapped out the water pump passages on the pump housing.
#6 is not visible from the back side
- Water inlet to deepest part of housing (pump suction side)
- Pump output (lower passage on back side) to drivers side of block
- Return from block (upper passage on back side) to outlet (T stat housing)
- Bypass hole between inlet and outlet
- Heater hose return to deepest part of the housing (pump suction side)
- Heater hose supply from block (upper passage on back) to heater core inlet
- Pump output (lower passage on back side) to passenger side of block
