I have a complete Disc brake conversion set up off of a 1974 Duster. Includes both spindles, both rotors, both calipers, both caliper stands, lower ball joints , inner and outer tie rod ends, both Large Ball Joint upper control arms. All hard ware is included. Everything will need to be gone thru and is the installers responsibility to determine what may need replacing. I do own a Ammco 4000 drum/rotor lathe and I can machine the rotors for you in you would like. Shipping these parts would be costly as they are heavy. I prefer local pickup or I you can meet be some where along I-75 between Tampa Fl. and Macon Ga. I can deliver them. I drive to Perry Ga. all the time. $325.00
