bbp disc brake setup
74360duster
JEREMY
JAMESTOWN,MO
what are big bolt disc brake complete k members worth.meaning:calipers rotors-everything.i have a junk yard 15 miles from my house that would sell them all to me for he said 150-200 dollars a piece if i removed them.probably has 5-10 cars with discs for sure. that i remember seeing
2 years ago I paid $90 just for spindles and caliper brackets at one junkyard and $45 for UCA's at another. They would be worth it.
Since you're doing all of the work to remove them, you should be able to negotiate a better price if you're taking all 6.
you really don't need the entire k-frame... split the lower ball joint and take from there up.... also grab the proportional valve,master cyl and brake push rod.. last set up like that i got from the yard cost me $150...
If you do it now, do you get the Mr. Snowman discount?
