BBP disc brake swap
AHamilton
Charleston, SC
One set of BBP disc brakes w/upper A arms and prop valve. Everything in pic pertaining to the brake set up is included. The rotor thickness on the hub assembly is not as nice as my last set...overall is 1", one side is 1/4" and the other side of fins is 3/8". Without hub assembly $250 shipped w/Hub assembly $310. I can fit everthing, except the hubs, in 2 flat rate boxes...each hub takes it's own box.
There is no seperate "hub" on the bbp setup, like the sbp setup; just the rotor and spindle. The "hub" you're talking about, that the spindle?
He is going off a post when he had these listed as small bolt pattern. These rotors can be trashed but the bearings and dust caps should be saved.
