Bent Radiator Support
dartslantsix
Klamath Falls, OR
My 67 Barracuda's radiator support is bent. I'm not really a body guy.
How would you fix this? Beat it back into shape? Too far gone... replace it?
If I can bend it back into place, any tips are techniques?
Thanks.
I'm not much of a body guy either, but it is probably stretched some and won't be as simple as bending it back to original shape.
Mine was tweeked in the lower passenger side to the point the self tapping thick peice of metal that is used to mount the radiator was stripped from someone trying to mount radiator.
Anyway, with no radiator or any other supports mounted to the panel, I took my palm and gave it few open hand pops and it fell back into place.
If it just bent at the bottom, a straight 2x4 and some c-clamps could walk it back into place and get it close. I guess it really depends on your expectations.
You could also get a metal shrinker and try that to get it back into place
....and you're on here askin US how to fix something? Nice job!
