mechanicmark
Need to do the 44re in my 98 jeep. What are the good aftermarket kits today? Have been away from dealership for 14 years and have never used a aftermarket kit. Thanks, Mark.
These are smoked, lots of end play. Broken up fiber thrust washer, shell has major wear.There aren't any. You'll need selective thrust button between the front and rear shaft ends. Also you probably have five direct frictions; most kits have four. Even the red eagle kits that have five for the direct aren't advisable because once you make the step to smooth high performance plates (they can withstand higher temps) you might as well opt for forward frictions; which are thinner (.061 vs .086); allowing six frictions in the direct clutch. There's a five plate direct kit on ebay for 204.87; you might inquire as to the thickness of the direct frictions. You'd probably be better off ordering ten alto red eagle forward frictions separately; that is if you want to order parts before you take it apart. Also the thickest middle thrust button.
