Who makes the best intake manifold gasket for the 360 magnum? I have narrowed it down to 4 different sets. fel-pro, victor reinz, edelbrock, or mopar performance. Another question I have, when installing new intake manifold gaskets, are you supposed to put silicone around the water ports on the head and intake, or just around the water port opening on the gasket?
I see people saying you should do that, but I have never done that in the past, just used the gasket and silicone at the front and back end rails.
If I do use silicone around the water ports is it o k to use the right stuff gasket maker? because that's what I like to use on the front and back end rails. Or will I be ok with just the gasket and no silicone around the water ports?
