Use the Joe Gibbs Driven assembly grease. It's the same or similar to the High Pressure lube Hughes used to send with his cams. Now he uses Driven. It's the thick, brown stuff. You can get it by the one pound little tubs. I know you're talking breaker points for ignition, I use it for that too!!
