Best Way to Clean Bare Metal in Interior?
Dragin Demon
Member
Austin
Howdy all,
I've got a '72 Demon that's completely stripped down to the shell and on a rotisserie.
I've vacuumed the interior as much as I can, but it's still fairly dusty with caked up dirt and dust, especially in the crevices in the rear seat area.
What would be the best way for me to clean the interior completely out to get it ready for sanding?
Thanks!
I used a pressure washer, inside & out.
C
Hot soapy water and a scrub brush then rinse.That is if you do not have a power washer.
I would blow everything out, clean real good w/ wax & grease remover,then paint everything w/ epoxy primer
Im pretty sure I wouldnt use water on bare metal. Unless you like rust
Comet cleaner works well too. I plan on hooking a hose up to the hot water heater and letting r' rip! A old school trick is to use a leaf blower after your done to dry everything out.
