63SplitWindow
Looking to buy my first set of race tires for my small block Dart Sport and I'm wondering what would be best for my application? Any insights into this?
Thanks,
Bill
Thanks,
Bill
I've ran the bias/radial mix both ways and have never had any issues. Drag radials or slicks? Depends, more info needed as DemonX2 mentioned.
Small block (approx 425 hp), 727 with 4500 stall,Be aware that on marginal tracks radials may not work well. The four link will help, good shocks will be a plus too. What's the combo?
You driving to the track, as opposed to trailering, run the Drag Radials, trailering run the slicks.
So I last raced 32 years ago when there were only slicks. Retired a few years ago, put a modest car together, that I drive to the track, so I got the radials, MT & then M&H. Both working pretty well, but found I spun the rim on the tire at 15psi last runs.
Never had that problem with the race only car as the rims were screwed since I only ran 4psi. Broke down the new radials and Scotch brighted the tire beads and rims with alcohol, so we'll see in couple weeks at the next race. My conclusion is the radial tires are sticking, ... and that's good.
Interesting.....this will be a track only car that will be trailered
They are supposed to dead hook at the track, that is in their design, whereas a slick is fastest when there is a little bit of controlled spin. I personally have only used the M/T drag radials for street and strip use.....never had a treaded tire on the BarracudaYou driving to the track, as opposed to trailering, run the Drag Radials, trailering run the slicks.
A good drag radial, which would not include Nitto are proven to be faster and more stable than a slick or bias ply......FACTSIf you run the car on the street i'd recommend not switching tires to go to the track and running M/T sportsman Pro tires. They are full tread, drag slick compound with a wrinkle wall design. I run 10's on them with 16-18lbs or air, dead wrinkled hook.
I prefer bias ply for the strip and in many cases on the street as well. IMO the popularity of drag radials is three fold.
1. They produce these in modern tire sizes
2. The next latest great bestest bullshit product you HAVE to have
3. Race classes that require them
If you go drag radial, which I advise against, they like a wide wheel. So if you buy a 12.5" section width tire, it wants a wheel damn close to that.
Your doing it backwards and if you haven't bought any tires yet you should get a set of 275/60/15 M/T Pro Bracket Radials and spread the tire out across your 10" wheel. The less sidewall "bulge" the better from at least a drag radial standpoint.Thanks Rocco. This will be a track only car so there won't be a need for tire changes. I have 15 x 10 wheels on the back and I was hoping to run about a 12" tire. Can I do that with a slick?
I don't race no prep, that is for the mentally challenged, I personally run one because the car see's double duty. The OP's car is track only I guess from what he stated and although I have never personally ran a slick on any of my cars I do know of a few people that have went from a slick to a radial and they all agreed that the radial is faster and it's more stable, if that is not your experience then it is what it is, but have you ran both styles to even be able to compare? Everybody for the most part really wants to run as fast as they can, and yes I understand the bracket racing aspect but still guys want to run as fast as they can get the car to do and then work on consistency from there, I mean if not running fast was so important then everybody would just race their daily drivers. I will concede to this although it doesn't take away from the other facts I have stated......a drag radial is a dead hook tire and if it spins they do not recover whereas a slick is fastest with some controlled spin and will recover a lot better than a drag radial. So there is that....So why would you run one? Unless you are running heads up no prep, you are bracket racing. The minute amount of time a drag radial may yield means nothing. You are going in a straight line, and I can't say my car has ever felt unstable, even up to 140+MPH.
