These are A body big ball joint upper control arms for the 73 and up disc brake swap. Blasted to bare metal and black etch primed. Ball joints are new Moog and bushings are new as well. The only catch is the ball joint on the right side (pictured) will not tighten up. Weld it, fix whatever you gotta do but needs attention. I found this out when I installed the new joint.
$100 plus shipping to cover the new parts plus you get one good for sure control arm.
Pm me if you are interested. Thanks for looking.
Located in Southern Wisconsin.
