[WANTED] Big block aluminum heads.
mycuda
Chicago/ Metro
Looking for complete heads, bigger valves/springs. Closed or open chamber.
preferred straight plugs. Let me know what you have.
Must be ready to run.
Thanks
D.
I have a new set of MP StageVI Max wedge Ported heads, P5249579 , ported and built by Jim Laroy ( IQ52). But they ain't cheap. PM me if interested.
Not familiar with those. Does that require special intake/headers to use?
Thanks D.
Standard intake pattern and standard exhaust thou the exhaust is raised .250 . But the ports are Max wedge size(bigger). If you serious I have pictures and flow sheet.
got a set of Zeeker heads (like indy - 1s except have internal oiling to rocker like stock) all they need is valve seals, have indy 1.6 rockers with them and an indy low deck intake 4500 pattern intake, would turn loose of it all for $1850 plus shipping
