[WANTED] Big Block Bellhousing #2892513
RustyRatRod
I was born on a Monday. Not last Monday.
Georgia
Does anyone have a bellhousing casting #2892513? I would like some info on it and maybe pictures to make sure it is what I need. Thank you drive through.
Does anyone have a bellhousing casting #2892511? I would like some info on it and maybe pictures to make sure it is what I need. Thank you drive through.
That's a part number, not casting number. Casting number is 2892513.
Ok, Thank you. Do you have any other information about it?
Aluminum bellhousing for use with 130 tooth 10.5" flywheel. 4.805" bearing retainer bore. Originally used 1970-1974 BB & 426H in B or E body.
I am looking for one that will bolt to an A230. That one supposedly has the dual bolt pattern so I think it will, but it will need the adapter ring.
Rusty,
I have one hanging up in my shed, not for sale, but I can take any pictures you need of it.
Rusty,
I'm just trying to determine if they have the A230 bolt pattern. Then I have to find one. LOL
not at the moment
One more question, Dan if you don't mind. Are the bearing retainers between the A230 and 833 interchangeable? In other words, can I swap an 833 4.805 bearing retainer onto my A230 that has the 4.35 retainer? Thank you.
2892513 is the casting number I need. Please let me know what you have. Thank you drive through.
