SO here is a common example of a 'wanted' ad that doesnt tell the complete situation. By doing so one wont get proper 'results'.
Do you want an 10.5" or 11" bellhousing? Oh and are you using a trans with a small or large pilot retainer? Most likely you need a small pilot bellhousing because all (most) stock A 4 speeds used the small pilot retainer (23 spline). Now there is certainly a way around that by rebuilding the trans with a large bearing case, but Im sure that wasnt just sitting in your inventory.
food for thought
red
