joel
big block engines /383/440/blocks/heads/intakes/ect,ect.
ENGINES
1965--383 cast 6-7-65 block & steel crank 250.oo
1965 383 clean dated 6-16-65 500.oo
1968--383 cast 12-28-67 assy 1-18-2 non h.p. block &steel crank
1969---383-cast3-3-69 assy 3-21-2 block&steel crank 250.oo
1969--383 cast 4-23-69 block& steel crank 250.oo
1970 383 dated 1-6-70 non h.p. shortblock 350.oo
1970 383 long block dated 10-10 69 H.P. -blockrods&steel crank 450.oo
65 413 block dated 4-2-64 no caps 100.oo
62-67 383 iron intake #2205968 100.oo
67-69 440 intake # 2806178 i have the following dates
5-18-68
10-11-67
100.oo
66 440 intake # 2206000 100.oo
65 413 intake # 2206000 100.oo
pair 516 heads 125.oo pr
70 440 iron intake #2951736--dated8-23-69 125.oo
big block water pump housings original iron diff cast #s avail.
67-70 383-hemi water pump housing #2780987--50.oo
big block power steering brackets 50.oo
big block 4 groove crank pulley for steel crank 40.oo
big block water pump pulley for steel crank motor
40.oo
air cond pulley and bracket for big block steel crank motor 40.oo
non h.p exh. manifolds 40.oo pr many to chosse from
stock rocker shafts 10.oo ea
stock rockers 10.oo-set
stock rocker spacers 10.oo-set
stock bolts and special spacers 10.oo set
located in n.w. pa
16412
usa
cant ship heavy items
local pick up only
ENGINES
5-18-68
10-11-67
100.oo
40.oo
located in n.w. pa
16412
usa
local pick up only
