Robert Wright
Rebuilt stock heads, 452 casting. These heads are not ported and valves are sitting at the same height across the stems within .025". Came off an engine with a hyd. flat cam with .507 lift on both intake and exhaust. $175 + shipping from east central Illinois. Or pick up.
This is a very special set of heads because each has 8 valves, the spark plug holes are located right next the exhaust ports, made of cast iron, and painted orange. Hurry cause they will sell quick!
I just realized that I forgot to mention there are factory head bolts, stamped steel factory rockers, shafts and bolts, and pushrods that go with the heads.
