[SOLD] Big Block Heads
Robert Wright
Oakwood, IL
Rebuilt stock heads, 452 casting. These heads are not ported and valves are sitting at the same height across the stems within .025". Came off an engine with a hyd. flat cam with .507 lift on both intake and exhaust. $175 + shipping from east central Illinois. Or pick up.
This is a very special set of heads because each has 8 valves, the spark plug holes are located right next the exhaust ports, made of cast iron, and painted orange. Hurry cause they will sell quick!
I just realized that I forgot to mention there are factory head bolts, stamped steel factory rockers, shafts and bolts, and pushrods that go with the heads.
