Big block HP exhaust manifold
T2R9
Conway, SC
I need a passenger side 68-69 big block HP exhaust manifold. Heat riser is not important but must be repairable. I would also consider a 70-72 Thanks PM me here.
As you are no doubt aware there are a lot of varieties, can you be a little more specific as to application or intended use?
Except for the A-body big block manifold, aren't all the right-hand 68-69 hi-po ones the same? (except fot the date codes)
