Ultrabell part number 92450 that sells for 332.00 new at Jegs. Purchased in 2009. This bell housing bolt on to a Chevy powerglide pump after the stock bell housing is cut off. I am including a TCI mid plate that bolts on the back of a big block and converts it to the powerglide bolt pattern. The bell housing has been cut for starter clearance that is needed because a Chevy starter is on the other side. Sorry I no longer have the bolts but should easily be bought at Ace hardware or Tractor supply. 150.00 plus shipping for both pieces.
