[Found!] Big Block roller cam
Darrell1
North Fond du Lac, WI
Looking for a big block roller cam, new or used. Preferably solid but might consider a hydraulic roller. Let me know what you've got.
I'm also looking for other parts (rockers, intake, valley plate, 3600-4200 stall converter, transbrake) so check out my other posts. Maybe you have multiple parts that I need.
I`ve got a brand new set of 9.400 long compcams pushrods that can be cut to any length. forgot I had them (7 yr. build) and bought a second set from hughs engines.
I have a Brand new in the box Comp cam if you are interested. I can get you specs later tonight when I get home. Also have T & D shaft rockers
