Big Block- Spool mount ?
draginmopars
Shady Hills, Florida
Have a 440 (1975) with spool mounts out of a "C" body.
Will those engine mounts fit a "A " body spool mount > K-frame
So, I can put a 440 in a a body:burnout:
Yes, you have mounts that will work if the k-frame is the V8 spool frame.
It will need modified some though.
Thanks,
Doing a little spring cleaning and noticed one of the 440's had spool mounts on it.
Was thinking about stuffing a 440 -1968 into a 71 Dart,
It has the 73 V-8 spool mount.
