Big block swap?
I do believe the steering linkage changed also. Might want to swap over everything to the 71.
If he is sayin his donor is a 73 with a already transplanted 440, then yeah, it will all bolt in the 71, like has been mentioned.
Welcome aboard. As said the K will swap & the 71 uses biscuit mts as opposed to the spool type on the 73 K so each one would take a different aftermarket BB swap mtr mt setup. Center steering link (either 71 or 73 will work) tho they MAY each require a different idler/pitman arm(s)
