[SOLD] Big Bolt PATTERN Disk brakes
jockeyshift
New Jersey
Rating - 0%
0   0   0
All parts Blasted&painted new big ball joints&offset bushings installed in uca.New balljoint.bushings&pivet pins,bracing plates installed LCA.Also strut bars with bushings,2 outer tie rod ends.Spindels ,calaper brackets,2 rotors with 3 inch studs.Also 4 bolt master cyclinder for disk drum brakes.$350.00 PLUS THE RIDE.Also have new 1.06 FFI Torshion bars $200.00. PLUS THE RIDER.If working on 63 to 66 dart I have new pitman arm & idlerarm $100.00 FOR THE PAIR PLUS THE RIDE.63 TO 66 K frame with FFI reinforceing kit $100.00 PLUS THE RIDE.THANKS FOR LOOKING IM installing a straight axle under my 64 dart:eek:ops:
