lilcuda
- Joined
- Apr 15, 2006
- Messages
- 1,122
- Reaction score
- 129
Another thing that helps with big cams is to drill a very small hole in both primary throttle blades. This allows more air in so you can close the throttle blades and get better idle mixture adjustment. If the throttle blades are open too much it exposes the transfer slot rendering your idle mixture screws useless.
