Can you post a link please. I went to his channel and looked for a title about main caps but didn’t find one.
Yup. I’ll see if I can find it.
curious on the cost? they look expensive. what was the final cost to have it all done, (engine machine work cost )The new owner of Pro-Gram Engineering, Billet Speed Works, can make the caps if you contact them. I had a complete 340 2 bolt set made last year. Be forwarned, it will take several months and are NOT cheap. You can opt out of the billet rear cap and save a good bit. But if youre gonna go through the trouble you might as well go all out and do it right.
I only did it because a production block is significantly lighter then an X or R block. If youre not confined by a particular class, I would go with the X or R block.
go right here to Hughes and read it.What is your process on how you install the main caps?
I know what you're saying I feel the same way. I just need to decide how serious I am.Ritter block lookin better all the time
When I asked him about it I specified for converting an R or X block from two bolt to four bolt.I spoke with Kent today and he does not do the caps individually any longer . He feels it compromises the integrity of the stock block. He stated a stock block could not handle any more than 600hp either way. He suggested I purchase one of his blocks and have the machine work done by a reputable machine shop. He figures the cost is in the $6500.00 area complete.
Those things do look like a thing of beauty though.The new owner of Pro-Gram Engineering, Billet Speed Works, can make the caps if you contact them. I had a complete 340 2 bolt set made last year. Be forwarned, it will take several months and are NOT cheap. You can opt out of the billet rear cap and save a good bit. But if youre gonna go through the trouble you might as well go all out and do it right.
I asked for his 2 bolt caps for my 360 block. Kent was very nice about it and expressed his thoughts on how he thought the stock block would be compromised.When I asked him about it I specified for converting an R or X block from two bolt to four bolt.
You wouldn't be nervous those roll pins would work their way out?
I thought all R blocks ARE 4 bolt blocks.When I asked him about it I specified for converting an R or X block from two bolt to four bolt.
I had a 2 bolt X block with studs.Nope. There are 2 bolt versions of X and R blocks.
You are better off starting with a 2 bolt block anyway.
The Ritter caps move the register to the outside of the outside bolt.
