KnuckleDuster
I bought a used shifter that is missing the pins and clips to block 4th gear and limit lever travel to park. Anyone running a 4 speed GM automatic took these out and might have them lying around in a box. I cannot even find a part number on the Internet. They go in the two lower holes on either end and are held in with c-clips. I know I could use a bolt or something, but thought I'd try to find the correct pins if I can.
Also interested in a cable, bracket and shifter lever for a 727 if anybody has those lying around too.
Thanks!
Thanks!
