mrdodge
Bunch of engines and parts for sale.
73 440 block, standard bore $350
70 383 block, standard bore $250
68 318 block, standard bore $200
steel crank from 383 may need turned $ 150
cast crank from 318 $100
346 heads from the 73 440 will need rebuilt $200 pr
complete 225 slant 6 from 69 d100 $225
73 340 complete except carb. needs bearings, good oil pressure til it warms up then drops below 20 psi. $1000
72 360 no carb or intake, has J heads needs rebuilt $550
2 BB 727 assume they need rebuilt $200 each
2 Sb 727 assume they need rebuilt $150 each
also have a 69 318 rebuilt short block, .060 over. no info on what pistons or cam was used. not sure if i want to sell or use for a project, will consider offers.
also have rebuilt J heads for the short block 1.88 valves.
I also have other engine parts and A body parts. also 61-71 Dodge truck parts.
Shipping is not included in prices. Will have a spot in the swap meet area at Carlisle and can bring parts along. All parts are located in Manheim,Pa
