Bodyman Help
6pk2goDemon
Mopar Mod
Arizona
The hood on my Demon fits terrible :angry3:. The passenger side of the hood is up close to an inch. The driver side looks great. What do I need to do to fix this?
Here's a pic
simple adjustment, just loosen the 2 bolts at the hinge- move the hood- tighten then slowly close and watch the gap. Might take a few trys to get the gap right. Oh and tape the edges so you dont accidentally chip the paint.
Cheryl, it's pretty easy but time consuming, and you'll need a helper to hold the other side of the hood while you loosen up the bolts on your side.
correct me if I am wrong here but the gap does not look like its off back and forth but rather up and down.....which would mean that the hood hinge has been bent up (due to possibly someone not latching the hood and wind catching it more on that side than the other? or the hood open and someone pushed on that side?
if that is the case I would say rebend it in the oposite direction or replace that hood hinge
