SLOPAR72
If the information with pictures exist on here I never found them so here is the skinny actual and factual.....
K member is position on the motor as it was in the car during my test fit. #3 tube will need some massaging and otherwise it's a fit. The fittings for the pump I have not tried yet but it appears to not be a problem. If you look closely at one of the pictures you will so may 20% of the attachment point for the box through the mounting hole. I will update this thread later on in the weekend after I assault (gently lol) my header tube and get this thing bolted up.
JW
JW
