B.R.E.Demon
Lastly motor 1 going to MadCap
Very, very Nice! Car looks pretty good too!
Fortunately at nationals the car will run comp eliminator so that's me vs myself. But for nostalgia pro (even the class we''re trying to do) there are now rules otherwise.that seems like a Smokey Yunick interputation of the rules...but I like it! (sorry for my bad spelling, they taught us "fon-icks" beofre teaching us how to spell correctly)
This car is being built as a one-time, money-no-object project—do it once, do it right. So if some unconventional tricks are involved, that’s not an issue for me. The steel inner structure has already been cut down significantly, with the bare doors now weighing just 22.6 lbs. At that point, the skins don’t really need much rigidity beyond some reinforcement around the handle area for the initial pull. The side windows will be Lexan with straps anyway. A fiberglass skin comes in at about 6 lbs compared to 13.5 lbs for steel, so the weight savings alone makes it a worthwhile option.Sounds like a decent idea but maybe more for like a big money/grudge/street race car. "Naah bro, these ***** are full factory steel....check it with a magnet...See? Give me two and the break..."
Might not be worth the trouble if you're going to keep the steel inner structure anyway. 'Glass skins weigh something especially if they need to have any sort of rigidity so it's probably a minimal weight savings. Lexan side glass and straps might be a bigger net gain.
Not sure if you ever found someone who still does chemical milling but if you can find a place I'd go that route.
So far, this car has fiberglass fenders, three hoods, a valance, front bumper, dashboard, rear sail panels, and two trunk lids. I’m no stranger to working with fiberglass in racing, so it’s never been an issue for me. When it comes to putting in the work, I don’t shy away—as long as the end result meets my expectations. And when it comes to finding the best approach, combining all available options usually gives the optimal outcome.Fair enough.
Beyond a hood and maybe a trunk lid I'm not a big fan of fiberglass body panels myself. Many years ago I bought a set of fenders for a car I used to own but never ended up using them. They just seemed too flimsy even at "street weight" and I couldn't see driving around with them on public roads. People have done it of course but it wasn't for me.
Plus, they also needed a ton of work to make them look halfway presentable. The dash I got for the same car was even worse at just a step above a shapeless blob. Door skins are relatively flat though so they're probably easier to make look decent.
Fiberglass panels are reasonable solutions for weight loss but there's other ways to "skin a cat". I'm sure you'll figure out how to make them work.
I’ve also been adding to the vintage sticker stash for when Tuki works his magic,
I see you had a new YouTube short, what did it make a million hp ?That is something I cannot wait to see. The car was killer before the tear down but now it’s just next level.
As far as the doors with or without a glass skin…I’d say go all in with metal in the resin and glass skins.
Yee Haw745/879 on 14psi.
Cool, I'm getting dizzy.Last night on the Bostonian rebuild, I dressed the new passenger-side reinforcement plate for the subframe connector. I also cut out the driver-side subframe connector and prepped it for its reinforcement plate. While I was under there, I scraped off a bunch of leftover undercoating that didn’t come off during blasting. I also started mapping out where the cuts will need to be made for the new rear rails. Progress has been steady, and I’m hoping to get a bit more done today so it’s at a good stopping point going into next week.
wait till I start cutting lolCool, I'm getting dizzy.
