Charrlie_S
I'm in the process of getting parts together for a new 225 motor. 225 block, 225 crank, 198 rods, and 2.2 NON turbo pistons (flat top, not dished). Then I need to do a "mock up" and see what the CR comes out at with no milling of the block or head.
PS: The "replacement non turbo pistons" require pressed pins, so the Molner/K-1 rods will not work. The turbo pistons can be used with pressed or floating pins.
