Bouncing Speedometer
Electrical and Ignition
  1. pacuda59
    pacuda59 pacuda59 FABO Gold Member
    5,075
    245
    Sep 20, 2005
    Pennsylvania
    Local Time:
    5:33 PM
    When I was driving out to Carlisle I noticed my speedometer was bouncing. I also passed one of those digital speeding readouts and noticed about a 5mph difference between me and the readout. Is this an indication of a bad speedo cable?
  2. oldkimmer
    oldkimmer FABO Gold Member FABO Gold Member
    12,611
    2583
    Nov 11, 2006
    Kindersley, Saskatchewan,
    Local Time:
    4:33 PM
    ................yes, take it off and lube it with graphite......u also need to go 1 way or the other with ur speedo gear.......kim.........
  3. Abodybomber
    Abodybomber Breaking street machines , since 1983.....:) Legendary Member
    31,729
    10465
    May 21, 2011
    Arroyo grande ca
    Local Time:
    2:33 PM
    Possibly,Pac.Most likely,pull ,inspect,replace if frayed.If so,you can buy a cut to fit kit(10.00 would be close,I recall).Either way,hit the cable with white lithium lube,areosol would be best.That way,you can shoot a couple of squirts in the housing,as well.Hope this helps.
  4. pacuda59
    5,075
    245
    Sep 20, 2005
    Pennsylvania
    Local Time:
    5:33 PM
    Thanks guys!
    Has anyone ever bought a cable from an outfit called Schumacher
  5. Abodybomber
    31,729
    10465
    May 21, 2011
    Arroyo grande ca
    Local Time:
    2:33 PM
    Too much coin! Check out Pioneer,unless buying a whole housing & cable.They do speedometer cable kits,housing usually doesn't need replacing. Measure your old cable,to the new one.Cut cable to match,crimp the square drive bit on,install.You are done!
  6. Hersbird
    Hersbird Well-Known Member
    952
    23
    Feb 20, 2010
    Missoula, MT
    Local Time:
    3:33 PM
    Mine was bouncing more at lower speeds but still some at higher. It wasn't the cable but the bushing in the gauge had worn and the arms were rubbing as they circled the bottom. I don't know the proper terms. I was able to clean it up and get a little more clearance and it's better but not perfect.
  7. Ma Snart
    Ma Snart Well-Known Member
    5,219
    68
    Oct 27, 2011
    Burlington Wi
    Local Time:
    4:33 PM
    Hi PaCuda59! Hope all is well with you and your family.
    Both my 61 Chysler and 71 Charger have had this happen. The Chysler liked to squel as well which was lovely.
    Pulled each cable out, put some grease on them, put them back in and fixed them both.
    Good luck with yours.
    Ma Snart
  8. pacuda59
    5,075
    245
    Sep 20, 2005
    Pennsylvania
    Local Time:
    5:33 PM
    Great....I'll try to fix it with these suggestions....thanks again!
  9. kt340sport
    kt340sport Well-Known Member
    1,732
    18
    Dec 23, 2006
    Miramichi N.B Canada
    Local Time:
    4:33 PM
    All my a body cars i had bounced at low speeds, if i remember correctly!!!!!
