Brackets for power steering slant six
ppsi
I am going to start working on putting PS on my 65 slant six dart. I have both style pumps available and a large number of brackets. My problem is I have zero idea how to put the pumps with the brackets that I have. I will try and post photos from my phone so if anyone might be able to help I'd appreciate it greatly.
OK, no luck posting photos via phone so I'll read up on it.
Thanks
These are most of the brackets I currently have.
Here are the two pumps. I have read that it is best to use the smaller pulley??? Better road feel???
Here are a couple of more brackets I couldn't fit into the first photo.
Thanks again
I believe the brackets in third picture are 70-up for the LA engine. The pump in the 2nd picture in the upper left is the same pump that came off my slant-equipped 65 Dart wagon. The bracket in the lower left first picture was used in conjunction with another bracket which bolted to the lower left on the engine ahead of the motor mount. Could not really make out if you have that bracket.
OK thanks. I have a 68 dart gt convertible that's coming lately apart so those brackets may go to it.
Maybe someone has pictures??? I've looked at several online but none show enough detail to allow me to see the exact brackets used.
