I have a very tight brake line situation on the early dart with the TTI headers
Has anyone used the Wilwood flex braided brake lines to replace the metal lines? I need to move the junction block and then run new lines from it to the master and then from the other side of the block to the front disc. The rear is not an issue I ran an entire new line and can bend it to fit OK. The current front metal lines are wrapped under the frame and are very close to the headers. I would have to put a lot of bends in the lines and there is little to no room to work to get them away from the headers. seems that these flex lines in the DOT rating would be the hot ticket.
Anybody have experiance going this route? Thanks!
