Brainstormin' 440 vs 5.9 ...
A lot of suggestions/thoughts on getting the 440 to work.... like 'em, thanks
What about the 5.9? I'll gladly put the few bucks into that to move the needle... (and no, still not doing the NOS)
452 and 906 heads should be cut to 80cc chambers!
But if you can find a set of 915 closed camber heads you can cut them to 70cc but one any of these he’d you will need to cut the intake side or cut the intake. You can actually get the compression up to 9.5-1 by decking the block and 80cc heads. I’ve done this with a 60 over 440 I did the pocket porting and port matching with 1.81/2.14 valves and the 557 mech Mopar cam. I did a refresh on this engine a few years back and put it on the dyno for the first time it made 545tq and 525hp with my 2’’ headers an 850 Holley. Carb size matters on a 440, 850 min.
I always ran this with a 3800 Turbo Action converter witch stalled at 4500 rpm low 11s in my Volary.
With the 440 you must do the head work and compression is very important, steel head gaskets are a must, carb size matters 850-950 and cam, if you’re using stock pistons your limited to maybe 5500 rpm, stock rods with good bolts 7000 rpm but I’d polish them.
The 440 is a good platform to build from, doing basic blue printing 500 to 600+ hp is easily accomplished with select parts using what Mopar designed
So turbos then.
I could just install the 440 as is and baseline it. I ran a stock 400 with 4bbl/headers in a 3700 lbs truck and ran 14.5 with a sticking brake caliper. I'd think the 440 would outrun that, but that's a long way from beating 12.9's
A 440 block with a piece of wood on top is pretty good for sitting on, while working on my small blocks.
That wouldn't happen to be one of the small blocks we sent off to the scrap yard. lol
We junked a bunch.
How much $$$ do you have in the 5.9? It's a little one sided to limit the 440 to $500, don't you think?
But then there's the pile of GOLD everybody thinks 915s are worth, PLUS the GRAND or more to work them. They're all worn out.
I think between those two, the 6400 is the clear winner. That said, look at the Nostalgia Road Runner cam Comp offers. It's got a really nice grind. It's a modern version with a 110 LSA instead of the 115. I don't recommend Comp, but Oregon has something close, I am certain.
The only reason I recommended the Comp is because of the LSA. Although Ken Heard argues that a wider LSA increases cylinder pressure because it reduces overlap. That's the exact opposite of everything you read in magazines and online. He's right though. A wider LSA does indeed reduce overlap and normally that does increase cylinder pressure. I know the 360 I had in my 71 Dart ran like it's balls were ON FIRE and I had the Crane magic cam in it. 114 LSA.
