[WANTED] brake booster WANTED
Are you looking for a rebuild able used one I have one I will be pulling out of a ‘72 Dart.
Shipping from 48048 Michigan and probably weighs about 30 lbs.
Almost forgot
‘72 Dart had Kelsey Hayes front disc brakes that is why it has a 60/40 master cylinder on it. All brackets/ braces go with unit. It is not froze or stuck but it has been sitting and will need rebuilding. If you want it it’s $100 plus $50 to ship. It will come to you just like you see it…. Without the Dart attached to it.
That sounds good. Will it come with the brackets and fulcrum, that bolt right to the firewall?
It will come with everything that attaches it to the firewall.
I am going to manual brakes.
Wilwood disc fronts and 11” drums for the rear.
Pulled…. I have to remove the brackets to reduce its size for a smaller shipping box, but you will get everything shown, except the cardboard and miscellaneous items in the background.
